ORIGINAL: 2slow2matter
My only complaint was that the split elevator used some goofy setup with one pushrod connected to another pushrod, all connected to a servo in the tray. I replaced all of the hardware, and installed dual servo's in the rear of the plane to eliminate the goofy linkage. But, with any ARF, one should be ready to do some extra reinforcement and replace some of the cheaper hardware. Still, a great flying plane.
IMHO the World Model pushrod connector is a very nice piece of engineering. I usually build from plans or kits and on several occasions I have bought the World Model pushrod connector for use in my plans built aircraft. Do not forget to make 90 degree bends in the pushrod ends before fitting the connector.
