RCU Forums - View Single Post - BME50 - can't get quite right
Old 05-05-2003 | 02:14 PM
gilcon
Default BME50 - can't get quite right
bdphil
If you're going to try the petroleum oil, make sure to note your needle settings and then pull them out and spray carb cleaner thru their passages. That will remove any build up of oil. Also that will work with the synthetic (if that's your problem) for a while, but the symptoms will return.
Hall
