BME50 - can't get quite right
BrianB,
I only have problems in the air if I can't get it right on the ground. At first I thought it was only happening in the air, but I soon realized that it was exactly the same on the ground. Sometimes it just won't come off idle without richening up the low end needle and sometimes it works perfectly. What were you thinking the problem could be?
Rein,
I have had carb apart recently and there were a few small specks of dirt so I cleaned the screen, removed the needles and flushed it pretty good. Then I changed the filter, fuel lines and rinsed the tank. It shouldn't be dirt, but I'm going to have another look.
It it starting to sound like a problem with the carb.. Either dirt or the oil thing. I'll solve this problem one way or another!
Thanks for all the advise.
Ben
