RCU Forums - View Single Post - BME50 - can't get quite right
Old 05-16-2003 | 01:01 AM
Desertrat's Avatar
Desertrat
Default BME50 - can't get quite right
I might be totally off base, but I had very similar problems with my 100. I thought for sure I was just too lean, but the plugs were black. Turns out it was overheating due to the design of my cowl - all the air was running under the engine, and not up and over the cylinders until I put in ducting. These things will store heat for a long time inside a cowl, have you tried running it without a cowl?
