RCU Forums - View Single Post - Axe cp gy240 problems
Old 05-03-2008 | 01:55 AM
Kaptain Chaos's Avatar
Kaptain Chaos
Default RE: Axe cp gy240 problems
Well I fixed the problem and guess what the problem was?
Well I said I flied it right out the box, everything worked as is supposed to no problems.
Installed 12AMP ESC soldered the wires Blue to negative and white to positive on the deans connector for the tail motor after that connected the power leads from the 12 amp to the 3-1's power supply used a deans connector all wired good to go.
Then I went ahead and installed my GY240 as the instructions instructed.
The heli would spin Right if I went left on the RUD stick, I checked all connections everything hooked up fine the motor beeps when the esc initializes the GY240 initializes just fine so I flicked the REV back to off, thinking it would solve the problem but to no avail, I then reversed the RUD on the Controller nope still didn't work.
So I looked at the tail motor positive was hooked to positive neg to negative, Suretocrash thought I should change the wires on the tail motor as he had to do that with his Blade CP to make his HHGyro work.
So after reversing the wires on the tail, my Axe-CP flies minty as ever, I don't even have to use the rudder to hover anymore, but why did it fly fine right out of the box? anyone else come across this problem?
