RE: MOBIL DTE Light ?
Joe,
is this the shell stuff you are using ??
SHELL VITREA® OILS
Excellent non-additive machine and bearing oils
Product Description
Shell Vitrea Oils are highly refined, high viscosity index, straight mineral oils that give excellent lubricating performance where rust, oxidation and/or high bearing and gear loading are not problems. Vitrea Oils have high viscosity indexes, typically from 90 to 100. They are available in nine ISO viscosity Grades from 13 to 460.
Applications
• often used as an aviation smoke oil • light duty hydraulic systems • plain and anti-friction bearings • spur, helical and bevel gears operating under moderate loads • machine oil equipment
Features/Benefits
• good water separation • very good oxidation resistance
Shell Vitrea 13 - 5 Gallon Pail 658105/6556505203$39.99
