Hi Saito Lovers
I need some advice, I run a Saito 100 in my Fliton Extra 330 Freestyle.
I use an APC 15X6 on 15% with a Saito plug and am getting 9400 rpm.
I know it sounds greedy but I’d like to see if I can get a bit more power.
How much of an increase in RPM do you think I could get if I switch to 30%?
My thoughts are that if I can get another 3 or 400 RPM I could use a bigger prop, maybe a 16X4W. I know that will drop the RPM again but hopefully no lower than 9300 or 9400 I started with.
Also is it worthwhile changing to an OS F type plug?
Many thanks
Don
