RCU Forums - View Single Post - Sig P-51B Mustang 'The Stock Build'
Old 05-03-2008 | 05:28 PM
Thorprops's Avatar
Thorprops
Default RE: Sig P-51B Mustang 'The Stock Build'
Ok Submikster, sounds like you're off to a good start. You may not need a second battery for the retracts if you have a 1800 mah flite pack. I use a HydraMax 2000mah 6v for my Hangar 9 60 warbirds with mech. retracts with plenty of battery capacity to run the servos. An extra pack may work ok if you need some weight up front. The second pack is good ins. though, so let us know how you set it up. The weather here in So. Cal is so sweet for flyin this weekend, I'm lovin it! [8D]
