RCU Forums - View Single Post - Engine timing profiles.
Old 05-03-2008 | 08:02 PM
SAVAGEJIM's Avatar
SAVAGEJIM
Default RE: Engine timing profiles.
ORIGINAL: SAVAGEJIM
At first glance of those numbers you are shooting for, I'd say, by first intuition, that those timing profiles would make any engine perform much better that stock. By my own initial guess, that is a timing profile that most modders would shoot for in a "stage1" or maybe even a higher higher mod level to get the engine to perform more in the mid to upper RPM bandwidths.
Aside from impoving volumetric effeiciency at higher PM bandwidths (which is what increasing timing profiles generally do), another consideration to bear in mind is deciding how fast is too fast. For long stroke engines, getting the engine to turn too fast can be a bad thing since the linear piston speed in the sleeve can cause several problems (primarily friction). Lets say a big block has a particularly long stroke and it is modded with a timing profile that can get it to 40000RPM: the linear speed of the piston will be much greater at 40000RPM than a short stroke engine also turning at 40000RPM. The friction could in this case be great enough to cause the teminal max RPM of the engine to only reach about 37000 and no amount of futher duration increases can get it to ever turn faster. (Of course, affecting the engine's terminal max RPM in only one major problem. Other problems include the lubricant breaking down due to tremendous heat from the friction, the inertia of the innards of a long stroke engine can be high enough to hamper acceleration, etc.)
Though considering linear piston speed was never discussed in detail before as a concern for shooting for a desired timing profile, it is definitely one of the factors modders do take into serious consideration. That (among other reasons as well) is why they say "Depending on the engine, I will only increase the duration so much." No, I do not know what the bore and stroke of the TRX2.5 is, but given the stroke of the 2.5 is known, I can calculate what the linear piston speed will be for any RPM.
And of course, there also is the consideration of materials science and the points of failures of differnt metals. Some engines might be able to actually rev to 45000RPM with no ill effects on the parts because of their geomtry of the inner parts. Other engines will result in the conrod journals "ovalling" out and finally snapping due to the massive foces of otating so fast.
