RE: Spektrum/matchbox/Isolator
HI, seems you can run into problems if you disconnect the receiver from the battery and then hook it back up, with out turning the transmitter off, the receiver goes into a slow blinking mode.
So when you turn off the receiver, you must turn off the transmitter.
Does that sound right.
Rcpete
PS, Thanks for the info Rob.
