Ok, I've just talked to my friend, and the painting tutorial will be happening on a Jetcat USA "Hotcat" canopy.
I'll basically be starting from the primer stage (assuming most know what to do with fiberglass for prepping) spraying overall base coat, some basic airbrush techniques, up through clear coating and polishing.
I don't think I'll put it up piece by piece, more likely I'll wait until it's done and do the whole tutorial at once.
If there is a SPECIFIC question you have, let me know (ie: priming techniques, what to use for body fillers, etc)
I'll try to cover it all as best I can.
Paints used will include:
Createx airbrush paints,
Testors model enamel
RM Diamont Poly Urethane
I'll probably be spraying primer and base coat tomorrow
Jeremy
