RE: Stupid Tuning Question
Quite literally, many of the current Walbro's on 50cc size engines are very sensitive. The closer you get to the optimal setup, the more critical the degree of "turn" on the screw. Also remember low affects high, but not the opposite.
Usually, the final adjustments on mine seem to be the thickness of the screwdriver blade + or - , so it is nowhere near "1/8th turn", but actually quite less.
