RCU Forums - View Single Post - Tamiya Pajero-Collective Build
Old 05-04-2008 | 09:42 PM
  #305
R/C fan-addict's Avatar
R/C fan-addict
Default RE: Tamiya Pajero-Collective Build
ah it'll be fun! I also want to install a dash in the interior as well as seats and a floor and stuff. I saw that someone had used fiber optic cable to get light from an LED into a light up dashboard! I will have 7 sets of lights when I'm done with all the exterior lights, so I have 1 spot left open for which I can hook up the dashboard light. I might also make the little orange light on the side of the truck functional too. I think for the headlights, fog lights, and I might add a light bar to the roof, for those lights I might not plug them into the unit, but instead just hook them up to a battery directly since they never need to flash or anything and I also don't like that the unit makes the white lights go down to 50% brightness if you're not driving since on a 1:1 car they are always at the same brightness, regardless of the car moving or not. That would free up 2 more spots so after exterior lights (not including the little side turn signal) I would have 3 open spots. 1 for the side turn signal, 1 for the dash (although this could also be hooked directly up to the battery) and then I may add a few other little lights... hehe! This truck should look awesome when I'm done with it! I'm really excited for it to finally arrive! Hopefully tower doesn't push the date back further, they already did that for my f350 tires. Did you get your tires yet tex?
