Help Guys. Very tail heavy stearman..
Mine was also tail heavy - a 'heavy hub' spinner nut may cure this problem. But more importantly, check the orientation of your 'N' struts. Very easy to get them reversed and this causes problems with incidences on the top wing. I thought I had mine on correctly but after checking it and then reversing them, the plane flew so much better.
Check the other threads on this aircraft - that will give you some help, too. Hope this helps.
- Scott
