ORIGINAL: solace67
One thing worth mentioning is that the joining rod doesnt go into the wing as far on one wing as opposed to the other. Really not sure if I should grind it down or not if it is indeed a problem in the wing itself
That's interesting. I bet there is a splinter of wood, blob of glue or something else down in that hole. It is also possibly that the wing just got assembled with a pocket that is too short. If you do end up having to cut the rod, it isnt the end of the world. like I said, I've had to do it on several planes. I think that the joiner tubes ore often just rough cut to the general size and require some fine tuning.
