RCU Forums - View Single Post - Composite-arf Flash with a Artes Falcon
Old 05-05-2008 | 11:59 PM
KC36330
Default RE: Composite-arf Flash with a Artes Falcon
ORIGINAL: linmoore
Eric,
which half of the bypass are you calling the bottom? Is it the half that is bolted to the fuselage or the half that is held on by the velcro strap?
Lin
the bottom is attached to the fuselage, the top is velcro'd on, and should be removed for optimal performance, it allows the turbine more air.
