RCU Forums - View Single Post - Engine mounting question
Old 05-06-2008 | 12:00 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: Engine mounting question
ORIGINAL: Campgems
Number three is your best choice. Get one of the Dave Brown mounts of the correct size for your engine. Drill and tap the mount to fit the engine. The Dave Brown mounts can usually be removed from the plane with engine mounted if needed. They have center lines cast on the radial part of the mount to make alignment a snap.
Amen brother!
Chondar take that cheezy mount find the nearest lake and throw it just as hard as you can. With those type mounts you will always be fighting a loose engine. Seems we finally got the word out to manufactures of kits many years ago and that type mount just about became extinct.
Seems as though now some of the misguided ARF manufacturers are now trying to pawn them off agine as their latest and greatest thing to the newbys.
Only just my opinion
John
http://www3.towerhobbies.com/cgi-bin...?&I=LXB874&P=7
