RE: engine stalling
Your engine is running lean. Not enough fuel. You need to open the needle valve to about 2.5 turns and turn it in until it does not sag when pointing up the nose. Your fuel tanks centerline should be even with the carb and if this is not possible your engine should be rotated and mounted on it's side.
