ORIGINAL: splitzed
I had it all mocked up last weekend with all components installed except the covering, ....................
I'll send some pics on another post.
splitzed,
Welcome, that sure looks like a clean build of the "PRO". If you get a chance post your progress in the finishing stages. I bet that SPE 26cc will stand her on the tail for a little while. I look forward to hearing about a successful maiden flight that required only a click of right trim [)] .
I like your idea of getting readings with your incidence meter. At least this way you will know where you started if you need to make adjustments.
If I can ever get going on actually building something, I plan to build my "Pro" so that I can easily adjust my wing incedence.
