RCU Forums - View Single Post - Need help with ID of this Cub
Old 05-06-2008 | 05:54 PM
av8ter
My Feedback: (33)
Default Need help with ID of this Cub
I have had a couple of 1/4 scale cubs over the years and I believe they were both Sig's. This one is not a Sig (I think), I recently aquired this one and I want to rebuild it. I removed the glass (bad shape) and the covering. Fixed the broken pieces and I want to replace the glass. If I knew the manufacture I could possibly find a cowl and some new glass. The windows are molded with edges to precisely fit in the opening and a glued in place. The windsheild I think I can duplicate with a flat piece. I also need a cowling. I snapped some pics so you guys that have been building awhile could help me ID the aircraft manufacture. Wings are 100" span and plug in over the spars and are secured from the inside with nylon screws. Then a cover over the center section with an overhead window. Any help with this would be great. I am also looking for the plans as well.
Larry
ID:	944410   Click image for larger version
ID:	944411   Click image for larger version
ID:	944412   Click image for larger version
ID:	944413   Click image for larger version
ID:	944414   Click image for larger version
ID:	944415   Click image for larger version
