How to setup a DX7i on a BLADE400.
Well you would think that using a dx6i and dx7i would be the same. Just the 2 radios up the same way and bind the one you want to use and go fly. Well Sorry, it doesn't work that way. Even Specktrum, and Horizon couldn't tell me why. They just said it takes a little more "monkeying." After posting and not getting a 100% answer, I figured I would document what works.
Before getting stated make sure you have the following connections at the receiver. Note - when i am referencing servos I am viewing the heli from the tail.
Aux 1 - bottom left servo just infront of gyro
Gear - single yellow gain wire from gyro.
Rudd - 4 wire connector from gyro.
Elev - wire going to forward left servo just in front of the motor.
Aile - top right servo infront of gyro
Thro- wire going to speed control.
Batt - not connected
Now make sure all the black wires line up to the - sign on the receiver. The single yellow wire connector goes in the same orientation as the orange wires.
DX7i Setup
1) Press down and the select button while turning model on
2) Use increase/decrease to select an empty model
3) Use access up to get to the menu that selects heli/plane, use increase to set that to Heli
4) Use access button and goto swash type menu, choose 3 servo 120 degree
5) Trainer, Thro recover should both be set to IHN
6) Goto input select menu, set Aux2 to F-Mod, set Gear to Gyro
7) Hit the select and menu botton at the same time to exit this mode of setup
Setting mode
1) Press down and select to get to D/R & Expo menu
2) POS 0, Aile, Exp (your preference around +40% for beginner really helped me), D/R 90%
3) POS 1, Aile, LIN, D/R 90%
4) POS 0, Elev, Exp (your preference around +40% for beginner really helped me), D/R 90%
5) POS 1, Elev, LIN, D/R 90%
6) Rudd POS 0&1 Lin, D/R 100%
7) Auto D/R Exp - all 4 items set to INH
8) Reverse CH's 2 & 4
9) Sub trim is up to you to work, suggest youtube videos for howto. Mine flys good at all 0's in this area. Yours might be a little different.
10) Travel adjust. All area are 100 both ways except RUDD which is L90 R90.
11) Swash Mix, Aile -75 Elev +75 Pit. +85. 3 servos 120 degrees, exp inh
12) Thro hold, hold pos 0.0% S/W Aile D/R, You can put it on a different switch but this is what I liked.
13)
Throttle Curve -EXP OFF
Norm L - 0.0, P1 - INH, P2 - 50%, P3 - INH, H - 100%
ST-1 L - 100%, P1 - 92.5%, P2 - 85%, P3 - 92.5%, H - 100%
ST-2 L - 100%, P1 - 92.5%, P2 - 85%, P3 - 92.5%, H - 100%
Pitch Curve - EXP OFF
Norm L - 35%, P1 - 42.5%, P2 - 50%, P3 - 75.0%, H - 100%
ST-1 L - 0%, P1 - INH, P2 - 50%, P3 - INH, H - 100%
ST-2 L - 0%, P1 - INH, P2 - 50%, P3 - INH, H - 100%
Hold L - 35%, P1 - 42.5%, P2 - 50%, P3 - 75.0%, H - 100%
14) Timer, down-t, 8mins if just hovering, 4:30 if flying around, once you are familar with your batteries, you can change these. Just hovering I was at about 10 mins.
15) I leave revo mix alone
16) GYRO Sens, Rudd D/R, 0:67 1:50
17) Prog.mix1,2, and 3 inh
Preflight Check
Turn TX On making sure the b400 model is selected.
Once on make sure throttle hold ( aile d/r sw) is on.
Plug in charged b400 batt
INPUT (stick/direction) | Look for
left / forward swashplate to lower
left / down swashplate to raise
right / forward swashplate to tilt forward
right / down swashplate to tilt toward the rear(tail)
right / right swashplate to tilt right
right / left swashplate to tilt left
left / left tail pitch slider moves right
left / right tail pitch slider moves left
Thats it, don't fly unless you verify these movements.
Good luck, please let me know if you found this helpful.
