Twin Engine Trainer
Well I did a little kit bashing. I took a Tower Voyager and converted it to a twin and so far it is looking pretty good. I'm using two OS 26 four strokers on mine and I think it will handle them just fine. I also used two GWS micro servos for the throttles. Don't realy need a standard servo for the throttle plus it helps on the weight. I also have an A-26-B (converted to a bomber) with TT40s on it and it flys like scale except for the take offs it litterly jumps off the ground. So I figured that it needed an extra inch extension on the nose wheel should help it out quite a bit.
