Flip 3D
I want it to FLIP as well !!, but once like many thought I knew better and gave a model loads of movement!! It lasted 200 yards!!
I wanted some feed back, I plan to use the "standard" movement on low rates and double movements on high rate with 50% Expo.
The two servos I plan to use at the rear are the Hitech 5245's as these give 5.5kg on 6v at 0.12sec.
The ailerons and rudder will use the Hitech 5475 or 5925.
From what you are saying about weight, If I fit the YS up front its going to need a bit of weight at the back to get the c of g back to the 150 point. If thats the case I may use the 5925's all around as I hate adding dead weight to a plane.
Has anyone used the metal hinges supplied or have you all thrown them away?
Thanks for the info
Peter
