RCU Forums - View Single Post - Pullstart or No Pullstart?
Old 05-05-2003 | 10:32 PM
WhiskyVR-4
Default Pullstart or No Pullstart?
converting a pull-start to non-ps isn't hard or expensive. Just be careful when you cut the little knob off the crank, and be sure to seal up that backplate when you put it on (a LITTLE O2 sensor safe silicon gasket maker and threadlock on the bolts).
As far as buying engines, I've never seen one where the non-pullstart version was MORE expensive, its usually the other way around.
