RCU Forums - View Single Post - Kit Bashing... Lets See Watcha Got
Old 05-07-2008 | 09:23 AM
  #38
Tango Juliet's Avatar
Tango Juliet
Default RE: Kit Bashing... Lets See Watcha Got
ORIGINAL: flyst
well i guess i got a little lost in the plans for my three channel Kadet...and had to buy a 9 channel radio and mix and couple channels to be able to use all the fun buttons...you will see the first change was tri gear to tail dragger, then add cut the streight wing for barn door ailerons...add the three light systems,with stearable nose lights..light up the insturment panel and cockpit...redesign all the tail feathers ,make a bombbay box inside the fuse ..add the extrernal bombs ,carve out a wooden cowling ...add a side door to hide all the on-off swithces and charging jacks ....make Barbies head turn and sew a lacy red bra for her, as you can not find lingerie for Barbie any more ..invert the engine ...find a set of wheel pants to have that 1930's look...make a momemade saddle for the night glider ...and well needless to say ...room for all 12 servos.....shew glad it is done and flying...next kit.....hummmmmmmm
Love the Big Banana! Did you change the lines of the fuse at all besides the cowl? I'm developing a kit bash of this aircraft myself to make it a single rear pusher with twin booms. Can you send me a detail of your Aileron modification? And did you make a one piece wing or two?
