RCU Forums - View Single Post - wing bolt block question
Old 05-07-2008 | 10:03 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: wing bolt block question
He is referring to a filler block INSIDE the TE of the wing
Like Charlie said, Balsa is fine. No need to reinforce the holes with CA.
However, you should also add a thin (1/6"?) plywood plate to the outside of the wing to help prevent the bolt heads from pulling through.
