RE: Antenna Mod Re-Post
Whether solid or stranded shouldn't matter as long as it is insulated. What does matter is the length and what it's wound around, almost anything can be used as long as it isn't ferrous material. It can be made of plastic, paper, wood, some even used a section of a glue stick. Just remember the length of the coil wire must be the length of the section of the antenna you are replaceing.
