RE: replacing the propeller on the super cub
if it's the hobbyzone supercub, the spinner is just pressed on........just pull it off. you will then see a bolt that just needs to be loostened to remove your prop. good luck...........
ps......those spinners are on pretty tight when the come from the factory.......you might need to tug a bit.
