RE: Very sloppy steering in Lightning VX!! Help!!
I will look at the servo saver but like I said I applied pressure to the spline right on the servo and it came back to center everytime. I had the steering linkage apart the other day and found that the servo saver was pretty tight and looked ok. The entire linkage setup was pretty loose so maybe there is too much slop in the linkage. A couple of ball sockets were pretty oval looking and very loose infact they could pop off rather easily. Maybe that is the problem you think?
Rob
