RE: Not that handy, man
It will definitely get easier over the next couple of planes! You can clean up the epoxy (if it's thin) with acetone - just be careful since it can take the color off the covering if used too much. Also, when putting one together next time, keep a spray bottle of Isopropyl (rubbing) alcohol handy as it will dissolve uncured epoxy so you can get it off right away. Good luck on your maiden!
