RE: Engine Offset In Pattern Plane
hi their
you need to trim your pattern plane as follows
assuming your aircraft does not have endless power you need to set ur airplane up as per the kit then hit the fieald then fly tha aircraft vertically upwards ( not so that it flies out of site but you need to see weather or not it turns to the left or the right as it slows to zero knots in the vertical.\
