Hi guys !
First of all i am not a newbie ! I am more than that !!!
The only heli i ve flown is a picooz.
I have decided to buy T-Rex 450 V2/Silver or Black with a 430XL 3700KV motor and RCE-BL35X esc.
My setup will be as following
1. JR X9303 2,4Ghz module
http://www.espritmodel.com/index.asp...OD&ProdID=6973
2. 3X Hitec HS-65mg
3. Futaba GY401
4. S9650 Tail servo
5. I am between AR6100 or AR7000
So what i want to ask is if you see any incompatibilities in the above setup.
The servos i will totally been needing are 4 or 5 ? (Because gyro often comes with servo)
Heli will be flown at a scale manner with a scale fuselage (sooner or later). Does anybody knows if i can find any tx setup so as to fly smooth (scale) and not so abruptly ?
I am aware that i should also get
Pitch gauge
swashplate leveler
Blade balancer
Is there any more to add to this ?
Thank you for reading/helping me and waiting for your replies !
