RCU Forums - View Single Post - AFPD Downloads
Old 05-08-2008 | 01:25 PM
flyX
Default RE: AFPD Downloads
Just sign up it's free
Look a the file path of where it got sent to.
Go into programfile...makesure there's not a duplicate.
Notice how rajul listed the different files path for different revision.
Some model won't show unless the revision is correct...even thou it got installed into the folder.
You just have to go into the model's folder in the aircaft folder.
Open the model's .TMD file with NOTEPAD
Change the revision to match the revision your currently using.
Some models will have .wav files (sound) in the zip folder.
Copy and paste the sound file into the sound folder.
For models without auto install.
Just create a newfolder and rename accordingly
Copy and paste (drag and drop) or extract all of the files from the ZIP folder into the newfolder.
Drag and drop the newfolder into the aircraft folder.
Some models won't have a preview image...make your own.
Look in other model's folder as a guide or reference.
