RCU Forums - View Single Post - need help
Thread: need help
Old 05-08-2008 | 04:47 PM
bigtreds
Default RE: need help
well I was way off on the weight Its just over 4 lbs. its made of fiberglass with some aluminum pieces built in it. the red stand in the pic is 7in from the top to the bottom of the boat and the 2nd stand is 6in. I will get pic on later of it . having a hard time getting the pic on the comp. with the 2nd stand it looks like it would set the engine more in the center of the fins. a pusher would be with the prop facing towards the back? that is what I would like.......... I said before I would spend around 100 for an engine forget that I said that [8D]. I will spend what ever it takes[8D] been looking on tower seems marine engines are a bit more then cars.
