RCU Forums - View Single Post - Need set up help
Old 05-08-2008 | 06:19 PM
tippy
Default RE: Need set up help
ORIGINAL: bustedparts
Well I have been reading the instructions. I had to go into the airplane instructions to find out were the other aleron got pluged into.It was kind of dumb that they didnt put it in the heli instructions.Other question is the swash plate.I have been doing some set up with the radio on and the front of the plate were the aleron servos attach to the swash plate.Is that going to be lvl with the chassi befor you spool up or is it going to be tilted forward and then become level when you use the left stick?
Assuming your left stick is the collective pitch/power stick then the swash should never tilt with this stick. The swash should only tilt with the right stick (cycle - aileron and elevator).
