Building
A good FLAT sturdy table is hard to beat. Go to the local lumber yard/Home Depot and buy an untexured ceiling tile (2x4 ft) for a couple of bucks to use for a building surface. If the wing ribs have an undercamber, you may have to shim the trailing or leading edge with scrap balsa as per the plan. Built that way, you shouldn't have any warps.
