RE: Spinner will not fit APC prop?
You can modify a spinner to allow a bigger prop to fit but only up to a point. If the spinner is way too small, no amount of mods will be able to make it work and still have the 2 halves of the spinner mate together properly. If you tell us what size of spinner you have we should be able to tell you if your in the right starting size at least. [8D]
