RCU Forums - View Single Post - Lipo lost capacity?
Old 05-09-2008 | 10:50 AM
grayle's Avatar
grayle
Default Lipo lost capacity?
Hi I purchased a 2100 mah 11.1 volt maxamps battery about a year ago and it will only accept about 900 mah of capacity on the charge. I use a triton jr. charger and a blinky balancer. I have less then 20 charges on this battery, Is there anything I can do to regain the lost capacity? I don't believe its my triron jr. because my plane doesn't fly as long as it used to. What causes such a drop in capacity? I have never let it get below three volts per cell, and the voltage when fully charged reads 12.4 volts. When my plane won' t fly anymore, I check the voltage and it's at 11.25. My plane is a GP Reactor 3D, Rimfire 30-35-1250, Electrifly 35 amp ESC and a 11x5.5E APC prop. I checked the amp draw when everthing was new and at full throttle it was pulling 25 amps. Thanks, Grayle
