Help pulling Brillelli 26 apart
[:-] Helo all, I crashed my plane with the Brillelli 26 and due to the impact bended the crankshaft a litle bit. I have the model with the flywheel. I want to pull it apart to carry the crankshaft to be proffesionally straightend. However I cannot even take out the hub since I cannot look inside to see what wrench i need to loosen it. The manual I got wit the model did not specify any part.
Can someone please tell me what wrench is needed to loosen up the hub? so that i can take out the fly wheel and then be able to pull the engine apart?
Thank you, Randy
