RCU Forums - View Single Post - engine mount question
Old 05-09-2008 | 06:19 PM
alfredbmor's Avatar
alfredbmor
Default RE: engine mount question
There is no problem using at least 1/4 inch thick plywood (Aircraft type) but you should also check the tank alignment to avoid running your engine lean.
