Ralph Cunningham converted G-26 Problem
HI All
I have a G26 converted by ralph. The engine has been setting around for about a year.
I mounted it on a test stand and it would not start, so I tried to trouble shoot it. Charged the battery, changed the spark plug. Upon testing the plug to see if it would spark, I was zapped by the plug wire, so there is/was ignition. I hooked a 12 volt voltage tester and it did not light up (maybe too little voltage between the plug wire and ground)'
Does anyone have any suggestions of more troubleshooting/suggestions?
I even tried to start it with a starter to with no change, could I disable the electronic ignition or just send it back to Ralph?
Thanks in advance
Bill
