ORIGINAL: Pat Roy
An engine needs three things to run; air, fuel, and spark. If you completely close off the carb with the choke plate you eliminate the most of air part. That's what the little hole is for.
I say a engine needs 4 things to run...Air,fuel, spark at right time and compression! Capt,n
