RCU Forums - View Single Post - Installing balsa sheeting
Old 05-10-2008 | 12:32 PM
ram3500-RCU's Avatar
ram3500-RCU
My Feedback: (221)
Default RE: Installing balsa sheeting
ORIGINAL: Dorsal
Hmmm - Does anyone know if that stretch wrap sticks to epoxy?
If not, it would be a great way to get epoxy/fiberglass/carbon/kevlar onto a fuselage or boat hull.
I have also used this process for Z-poxy and glass on the underside of my P-38 crew pod. It worked great and DID NOT stick to the epoxy glass. Unlike sheeting though, more care must be used in applying the stretch wrap so creases and wrinkles don't create ridges in the epoxy surface. I had a couple that needed sanding, but they were only in the epoxy and not the glass. Once you slice the wrap and release the pressure, it pops right off, and it held the glass tight to the surface nicely. Here are some before and after shots. I guess I didn't get one with the wrap still on. Next time.
ID:	946686   Click image for larger version
ID:	946687   Click image for larger version
ID:	946688   Click image for larger version
