RE: Precision linkage Setup????
Question 2 - If no soldering is required...what would I use to replace the existing pushrods? THe rods I am using now are threaded on one side and bent at 90 degrees on the control surface side. I know they sell pushrods threaded on both ends in various lengths...but do these lengths usually fit all planes? Ive been told it is NOT a good idea to use the rods that are threaded the entire length of the rod.
Question 3 - This setup would only be advantageous to pattern flying? Would I not be able to get as much out of 3D as well with this? Is this where I kind of have to make a choice for this particular plane?
Thank you for the detailed response! Bravo is right~
