ORIGINAL: foresterxt
Thanks for the pointers guys. I am in fact using the stock plug (Fench chen?) and I do have the original V3 with the black plastic IE. I'll try and track down an NGK or Champion plug. So Don, You just elongated the holes on the hall sensor and slid it clockwise (looking at it from the front)?
I should also add, I did not having any missing on the ground, only once she was in the air. I was turning a PowerPoint 20x10 at 6600rpm, I'm not sure if that's good or bad.
Yes I just made the slots bigger. But make sure your setting it right. Do yourself a favor and buy a RCEXL ignition you'll be glad you did.
A 20 - 10 prop is a lot of prop for one of these new !!! I've been running an 18 - 10 MSC ( wide prop ) on mine. I have 2 gals through mine and I would NOT use a 20 - 10 prop just yet.
