ORIGINAL: Sarah
Hi Guys,
I've finished my Angel and did the maiden flight today, very impressive! I've got the standard A50-16S setup with an 16x10 APC, the climb is so good.
One little problem is that the Li-Po's (FP6S3700 & TP6S 5000) rest against the esc and it gets a little warm as there is no airflow over it. Has anyone resited the esc?
Regards,
Sarah
I mounted mine on the bottom of the motor box with a zip tie. The ESC gets direct air flow from the opening in the cowl :-)
