RCU Forums - View Single Post - Wing/Fuselage Joint
Old 05-10-2008 | 06:36 PM
AviationNut
Default RE: Wing/Fuselage Joint
I like the epoxy with micro balloons method. Spread some on the fuse, then put wax paper on the wing and bolt it on. Let cure then sand the sides even with the fuse. Sometimes takes a couple applications to get all the gaps filled - depending on how bad it is to start with.
