RE: How to determine if piston and liner need to be replaced?
You've nailed it downunder. I've never used an air filter which I'll be getting with the new piston and liner plus a fuel line filter which I didnt use either. I hope this prevents this type of wear of happening again. I should note that this engine was not properly broken in and I don't know if this might have affected the final result.
