RCU Forums - View Single Post - DIRECT DRIVE TAIL ROTOR
Old 05-11-2008 | 11:42 AM
GotM
Default RE: DIRECT DRIVE TAIL ROTOR
I converted my AXE CP to a direct drive tail using a Blade CP tail motor mount. It took about 30 min to complete. Overall, it seems to remove some of the yaw that I was needing to counter with tail inputs. Now, I need to find a black prop
The Blade CP mount is a little longer than the AXE, I moved the tail boom into the fuselage to put the overall length close to the stock set up.
