RE: OS 91 DF Engine
grbaker, That sounds like some good advise and I'll give it a try. I am using an electric starter with a long starter wand and yet the engine will start backwards. I do the quick throttle hit but no help. I also pinch the line until the engine almost dies then let go and sometimes that will work. I will definetly try to set the low end as you recommend.
